Prusa3 is showing an error in octoprint. It says the raspPi is reporting under voltage. I tried cycling power and a reset from the front panel but the error persists.
That’s more or less fine. Unless it is exhibiting some other issue you can ignore it.
Thanks Christian. I took a chance and ran a print anyway. It did ok, just wanted to report the issue.
On Fri, Feb 10, 2023, 18:11 Christian Kindel via MakeICT Forum <noreply@talk.makeict.org> wrote:
| Christian MakeICT Member
February 11 |
