Prusa is currently down
fyi the prusa os out of order. nothing major should be back later today.
What’s wrong with the prusa?
nothing now. someone was printing with wood pla it had a major nozzle clog. it ground off the filament after the gear. there was a not saying not extruding.
i wanted to clean the nozzle instead of replacing it. i had to try to the filament stub out. the part holding the gear shaft broke while opening up the door. so i had to print another.
when i could not get the filament out i had to pull off the nozzle and push it out. it also was baked into a chared mess so i had to swap the nozzle.
all done.
