The switch on the Powermatic belt sander is not working. The switch is spring loaded and it returns to the on position without shutting off the machine. It is now unplugged. Electrical work is not my specialty so I did not attempt to fix it. If I recall correctly this has happened before. If someone who has repaired it before, or has electrical experience wants to take a look at it that would be great. Otherwise I will see what I can do when I’m back up there.
