Outlets not working for wheels
The outlets on the wall where the wheels sit will not work.
I had someone try the breaker switch a few times and the outlets still won’t function.
This will definitely need to be looked at soon.
Somewhere along the line there with those outlets is a GFCI outlet. I’d check that to see if the GFCI has been tripped and try hitting the reset button. Follow the conduit around the room from the wheel outlets either way till you find it.
I’ll look at it tomorrow over my lunch break if someone doesn’t report back that they got the power back up and running.
The GFCI is reset, the Tormach lights are on the same circuit.
I’ve already left.
I ended up finding a extension cable so I was able to utilize the space earlier for my class but it will definitely need to be looked at tomorrow.
Sorry for the inconvenience.
For future reference, where is the GFCI outlet located?
It would be tricky to find for ceramics, the conduit passes through the wall between ceramics and the tormach and is in the corner behind some metal scrap. Mark helped me figure it out when the tormach wasn’t working.
