I’ve checked the calendar and don’t see any Wood Shop safety courses listed in the near future. Is there any chance one will be scheduled soon? If not, is there a way my son and I can set up an appointment to come in and get trained/certified? (I’ve been trained/certified at the McConnell AFB woodshop in the past, and worked with the 4-H woodworking projects, so not a total stranger to using woodshop equipment.)
Thanks,
Keith
There will be another following the next maker Monday. May 9.
Thank you Doug. Do you know what time that safety class will be on the 9th?
Thanks,
Keith
Hi, Doug,
I’m also interested in this class if it is in the evening. I’ll keep an eye on the calendar. Dale Roberts
I could be wrong, But I believe Doug meant that there would be a class scheduled sometime after the 9th. His safety class is usually the same week as the Maker Monday, but not on a Maker Monday , if that makes sense.
Thanks for clarifying, Jeremiah. I intended to put this at SLIGHTLY different days this month. I’ll have one on the 11th, 6-8pm and another on the 30th from 6-8pm.
Thank you Jeremiah and Doug. I have a schedule conflict on the 11th, and so will try to make the one on the 30th.
Keith
