Does anyone know if the woodshop has a drill chuck for the larger jet lathe? I am planning on turning a lamp base and will need to drill a long hole through the center for the wires once I have finished with the spindle and drilling with the lathe is going to be the easiest way to make sure the hole stays square.
I think so but I’m not sure.
It does. It’s in the wooden holder on the shelf with the lathe tools
Thank you, I didn’t think to check when I was at the building yesterday.
You’re welcome
