HDMI Port Splitters?
Ive been looking at getting a 4k monitor as a separate monitor on my workstation, but I only have 1 hdmi port on my computer and will need 2. Ive seen hdmi splitters but I think they only work for screen mirroring. I need them to be separate/extended screens. Anyone know anything about these?
Thanks!
Yeah, I’m pretty sure there isn’t any kind of splitter that will do that. Do you have any other video outputs?
Dual-link DVI-D… and a Display Port apparently. I didnt even know that was there.
Its an MSI Geforce GTX 1050
Just get a DVI -> HDMI adapter for the lower resolution screen. I’m pretty sure DVI won’t do 4k, but the video signal is the same as HDMI and the adapters are cheap.
Or a DisplayPort -> HDMI will probably get you a higher resolution if you need it.
I would have to do the display port>HDMI. The lower res display is a graphic display tablet and requires an hdmi.
Thanks Christian!
Tobias didn’t like his small screen on his school issued Chromebook. He can pick and choose what’s on the TV and what’s on the Chromebook. Not sure it will work for your situation.
https://smile.amazon.com/gp/product/B074HZMCQ3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1&fpw=alm
So now Im wondering… Looks like DisplayPort>HDMI adapters only have 30Hz refresh rate at 4k. Higher refresh rate means bumping resolution down.
I dont need 120hz refresh rate but why wouldnt I if I could?
Do you think the graphic display tablet could go on a HDMI>DisplayPort adapter? It isnt 4k, just sends stylus data I assume. I guess I could try it and return the adapter if it doesnt work.
That wouldnt work for me. But I see your on smile.amazon! :slight_smile:
Hmmm, I’d say it’s unlikely that the stylus data would be carried through the adapter if it’s coming over the HDMI cable. What’s the model of the tablet?
So Ive been looking at the display tablet and theres actually a USB and HDMI used. So the data is probably over usb and only display through HDMI. This is the tablet btw.
Speaking of which I have a old Wacom 21ux Im not using if anyone is interested. Its heavily used and has issues. Bought probably 13 or 14 years ago. Dropped the pen 1.2 million times so its got tape holding the non-working (and dumb) eraser on. (tape must remain attached or the pen falls apart) Its also got a strange issue with the display. It might just be me since i used to look at it 8 hours a day but the screen seems to have a ghosted image about an inch to the side of whatever it is showing. Overall it works though. It was the best of the best about a decade and a half ago.
Okay, in that case you should be good. All the input data should be over the USB.
I had a spliter once it was junk out of the box kept overheating
If it is a pc id add a slave card with 4k capability
Sure, you could add a second graphics card if you have the capacity for it, but why do that when you can get a $5-$10 adapter that works just as well? I use two of these Displayport->HDMI adapters with my desktop and they’ve been working great for years. DVI->HDMI adapters are completely passive since the digital signal does not need to be converted, so there isn’t even a possibility of overheating or electronics failure. Either should work fine for the drawing tablet in this case since it’s only 1080p.
I found 4k adapters for about $10 to $15. The monitor is from Newegg. 27" 4k only $270 in case anyone is making a Christmas list!
I didn’t realize dvi>hdmi is completely passive. That might be even better.
Yeah, that would be my first choice personally. DVI->HDMI for the tablet and the 4k monitor directly to the built-in HDMI.
I dont know about quality but I use a 40inch 4k smart TV from LG for my monitor picked it up on sale like 120$ few years back probably cheaper now.
I mean it looks really good but I’m not a pro
Thats pretty cool! I looked around at smaller 32" 4K tvs and they seem to be priced higher than the larger 40" and up TVs. I wonder if its the pixel density that makes smaller 4k more expensive. They dont provide many specs like monitors do.
I really want higher pixel density.
A standard 24" monitor has a screen resolution of 1920x1200px and is 94 pixels per inch (ppi).
A 27" 4k monitor has a screen resolution of 3840x2160px is 163ppi
A 40" 4k monitor its 109ppi
A 43" 4k monitor its 102ppi
Print resolution is usually around 300 ppi/dpi.
Another bonus with the 27" monitor is it is capable of displaying HDR. Which Ive actually never physically seen. And I wouldn’t use full time anyway. But… HDR in 3d editing land is used for lighting 3d environments. Rather than placing lights by hand into a scene, one would use an HDR image as the light source and the program would light the scene based on the HDR data in the image. AND as a bonus bonus the Display port on the geforce 10 series card can handle hdr.
