Facilities 5/19/2026
Much was accomplished, if you wish to join our weekly puttering sessions you are always welcome:
The old, and long past useful life, blades on the lawnmower have been changed. Facilities purchased 6 (it uses 3) heavy duty Gator mulching blades that should give us years of performance with regular maintenance. The mower is ready for work, but other mower maintenance issues were noted:
  • missing center deck wheel
  • center blade quill has a wobble and likely needs to be replaced
  • squeaky transmission
It is likely okay to leave these until the fall but preventative maintenance is better attended to immediately, Facilities will explore our options for servicing the riding mower.
John Cummings has rehabilitated a walk behind string trimmer and mower. They are now available for use in maintaining the grounds.
Poison Ivy present on the North wall of the building was sprayed around 12 days ago with a combination of salt, vinegar and dish detergent which appears to be an effective herbicide as the poison ivy is desiccated.
The batteries in the ceramics room towel dispenser have been replaced with new rechargeable D cell batteries
Many, Many, Many things were re-organized in the garage, a plan was hatched for even better organization. Facilities asks that t
Sanitizer and Detergent bottles were refilled and redistributed throughout the building
Discussions regarding the possible location of an underground junction box on the North end of the parking lot. We know where the big light pole breaker is, we know where the timer is, we know there are wires but we cannot get power out to the pole. More exploration is scheduled for later date in immediate future.
58 days have passed since the Board ended our contract with Service Master. Facilities has not been informed of their plan for replacing the service. We are concerned that the common areas of the building are not being cleaned and they are beginning to really show the neglect. We are concerned that the bathrooms are not being cleaned and are now rising to the level of constantly unsanitary. We ask all members, if you are cleaning the bathrooms, hallways, or sink areas please make sure to note your time on the volunteer time sheet so that someone will have some idea if it’s being done by anyone. We are not asking for a heroic individual, we are asking that the need for a sanitary facility be taken seriously by those members of the current administration that voted to end weekly janitorial service.
I’m assuming that you’ve ruled out bearings as the cause of the spindle wobble? I’m not sure which spindle that mower uses, so maybe it’s a moot point since some of the imported spares are as expensive as the bearings by themselves.
It may be the bearings, we did not disassemble the quill to find out, it’s more likely a worn bushing since the spindle rotates freely with no drag but wobbles inside the shaft. It’s a TORO and I feel they’re relatively opaque on parts, but really this is just an issue of timing, as in, we just discovered the issue and haven’t done any sort of further investigation yet.
We may revisit the issue after we get the new metal shop fans hung and the new exhaust for the water heater sorted. Though we are always open to help from those that are knowledgeable or able to
We have concepts of a plan now. Details will be posted very soon; figure nothing commercial will respond on a holiday weekend anyways…
Have we moved past using robots?
I think we like them for vacumming? Maybe? I think the mop bots are out of the question for now.
If the Roomba is the best we can expect from a robot vacuum they’re marginally better than not bothering at all.
