Metalshop Safety Class
Time: May 25 10:00 AM - 11:30 AM
Host: Rustin Atkeisson
Register: http://makeict.wildapricot.org/event-6187371Price: MakeICT Members - $0.00
Price: Non-Members - $20.00
Ages: 16 and up
The Metalshop Safety Class will cover basic safety for working in both the Hot room and Cold room for the Metalshop at MakeICT, as well as some basic expectations. The following tools will be covered :
Pipe bender
Tubing roller
Metal shear
Large and small sheet metal brakes
Drill press
Hand grinders
Horizontal band saw
Vertical band saw
Chop Saw
Other equipment not listed may require further authorization. This class is required before taking most other metalworking classes or workshops.
Safety glasses are available but we recommend bringing your own if you can.
Metal Lathe Basics
Time: May 25 12:00 PM - 01:30 PM
Register: http://makeict.wildapricot.org/event-6187372Price: MakeICT Members - $24.00
Price: Non-Members - $29.00
Ages: 16 and up
Metal Lathe Basics will cover the basic parts of the metal lathe while also going thru the proper use and operation of the Craftsman and Logan metal lathes.
The end project will include basic operations such as facing and parting as well as knurling and adding internal threading.
Safety glasses are required.
Intro to MIG Welding
Time: May 15 06:00 PM - 08:00 PM
Host: Larry Meeks
Register: http://makeict.wildapricot.org/event-6187577Price: MakeICT Members - $20.00
Price: Non-Members - $25.00
Ages: 16 and up
This class will teach you the basics for Metal Inert Welding (MIG) and set up on the Miller 211 welder.
We will cover use of MIG welding in the Hot Area and general welding safety.
Just showing up does not get you authorized!
Hopefully everyone will get at least 30 minutes of welding practice
You will need to show that you can follow instructions,
show learning ability and must pass a test.
Long sleeves are recommended. If you have your own welding helmet and gloves your welcome to bring them.
This class will show us if you are ready to step up to a (Tig) Welding Class!
Woodshop Safety Class
Time: May 24 01:00 PM - 03:00 PM
Host: Matthew Cleary
Register: http://makeict.wildapricot.org/event-6194131Price: MakeICT Members - $0.00
Learn the basics to safely operate the major woodshop tools in this safety class, including understanding the limitations of each tool, the forces created when using the tool and how to maintain safe control for improved performance. Tools covered: SawStop table saw, drill press, band saw, router table, jointer, planer, miter saw, oscillating spindle and belt/disk sanders and scroll saw. Expect around an hour of walkthrough with our tools and equipment, followed by an OPTIONAL hour of hands-on practice with the tools aimed at those who have little or no practice with woodworking tools.
Prerequisites: Please read the woodshop tool access policy and safety requirements on the wiki page prior to coming to class. Safety Personal Protective Equipment (PPE): • Mandatory: Closed-toed shoes, eye protection, short sleeves • Advisable: Hearing protection.
Upon completion of the safety demonstration, you can use this woodshop equipment for your projects whenever you work at MakeICT as a member!
New Member Orientation Tuesday
Time: May 20 07:00 PM - 09:30 PM
Host: Membership Committee
Register: http://makeict.wildapricot.org/event-6121435Price: MakeICT Members - $0.00
New Member Orientation sessions are required for all new members and exist to familiarize you with the building and the organization. To qualify for this session, you must fit the following requirements:
- Membership profile completed and approved
- Waiver Signed
- Payments are all current
This session will including a short slideshow about MakeICT and then an in-depth tour of the facility. Members will also sit down with a number of leadership and peer members for a brief discussion to allow us to get to know you. At the end of this session, you will get your key to the building so that you can come and go as you please.
https://makeict.wildapricot.org/Sys/Login
Membership Committee Meeting
Time: May 20 06:00 PM - 07:00 PM
Discuss Duties and Responsibilities of the Membership Committee.
Build a happy, informed, and engaged community of members.
Grow membership base
Host Maker Mondays
Recruit and train volunteers for orientations, tours
Improve member experiences
Support security in providing a safe environment
Jewelry Lab Authorization
Time: May 23 06:00 PM - 07:00 PM
Host: Ted McMullen
Register: http://makeict.wildapricot.org/event-6196990Price: MakeICT Members - $0.00
Get acquainted with the tools used in the Jewelry Lab, and make a silver ring with Ted McMullen. (small additional cost for the silver)
Embroidery Machine: From SVG to embroidered design
Time: May 31 01:00 PM - 03:00 PM
Host: James Lancaster
Register: http://makeict.wildapricot.org/event-6202945Price: MakeICT Members - $10.00
Price: Non-Members - $15.00
This class will cover using designs in Inkscape to convert/digitize using the Inkstitch extension into designs to use on the embroidery machine at MakeICT (or others.)
It will cover:
Designs which work and don't work.
Converting designs to work using Inkscape.
The conversion process to a stitch file and simulation.
Loading on the machine at MakeICT.
The embroidery machine setup/use.
Recommended:
Basic familiarity with Inkscape or an Inkscape class.
Have Inkscape and Inkstitch installed on your laptop or use one at the space.
How to teach a Class Class
Time: May 27 06:00 PM - 07:30 PM
Host: LaDeana Dockery
Register: http://makeict.wildapricot.org/event-6203664Price: MakeICT Members - $0.00
Price: Non-Members - $0.00
Class for people wanting to teach a class at MakeICT. We learn how to propose a class, how to check in students, how to use the projector and answer any other questions you might have!
