Event Updates for May 2023
CNC Plasma Cutting Basics W/ Fusion 360
Time: May 04 05:30 PM - 07:00 PM
Host: Jimmy Tennant
Register: http://makeict.wildapricot.org/event-5266705
Price: Non-Members - $25.00
Ages: 16 to 120
Learn how to use the cnc plasma with fusion 360. We will walk through the basics of programming a file in fusion 360 and cutting it out on the plasma cutter. Please view the wiki page as it has the material we will be using in class. Will move quickly through it so its nice to know it beforehand!
Time: May 11 05:30 PM - 07:00 PM
Host: Jimmy Tennant
Register: http://makeict.wildapricot.org/event-5266706
Ages: 16 to 120
Woodturning: Maker Monday Edition
Time: May 22 06:30 PM - 08:30 PM
Host: John Nicholas
Register: http://makeict.wildapricot.org/event-5268754
Price: MakeICT Members - $10.00
Price: Non-Members - $15.00
Ages: 12 to 100
Makers should make things on Maker Monday. Turn something simple to find out what woodturning is about.
We will have several experienced woodturners, Members of South Kansas Woodturners, available. This week we are working on containers. Shape the outside, shape the inside. Join our Instructor John Nicholas, Past President of SKW.
We wear Protective Face Shields (Safety) when turning. Dust or Cloth Masks are optional.
Kid Friendly, requires Parent with those under 16.
This exploring Woodturning Class does not require Woodshop Safety or Lathe Authorization.
Time: May 08 06:30 PM - 08:30 PM
Host: John Nicholas
Register: http://makeict.wildapricot.org/event-5268753
Ages: 12 to 100
We will have several experienced woodturners, Members of South Kansas Woodturners, available. This week we will turn a penl. Join Bill Oden, President of SKW.
Basic Fusion 360 (part 1 of 2)
Time: May 19 07:00 PM - 09:00 PM
Host: LaDeana Dockery
Register: http://makeict.wildapricot.org/event-5269025
Price: Non-Members - $20.00
Ages: 16 and up
This is an introduction to fusion focusing on building 2D sketches. This class will be 2 days long, each being a 2 hour class. You will only register for the first class, but will be expected to attend both.
The first day will include
* Creating and editing sketches
* Panning, zooming, rotation
* Creating sketch elements like lines, curves, circles
* Trimming and offsetting sketch elements
* Constraints
The second day will include
* Parameters
* Extrude
* A small project of your choice to be made on the laser cutter
Basic Fusion 360 (part 2 of 2)
Time: May 20 07:00 PM - 09:00 PM
Register: http://makeict.wildapricot.org/event-5269026
Ages: 16 and up
* Constraints
* Parameters
* Extrude
Laser Cutting Basics
Time: May 13 03:00 PM - 05:00 PM
Host: Christian Kindel
Register: http://makeict.wildapricot.org/event-5270379
This class will teach participants how to use the 80 watt CO2 laser cutters at MakeICT. We will be using the LightBurn software to create and cut a simple project.
Participants will learn the capabilities of the laser cutter, machine and material safety, and operation of the machine in Cartesian (flat) mode. All participants will complete a small project to practice running the machine.
Please bring a USB flash drive if you have one. Completion of this class grants the necessary authorization to use the laser cutter.
3D Printing Basics
Time: May 15 06:30 PM - 08:30 PM
Register: http://makeict.wildapricot.org/event-5270380
Ages: 12 and up
Learn the basics of 3D printing and how to use the printers at MakeICT!
We'll cover how 3D printing works, materials used in 3D printing, importing 3D files into slicer software, and important techniques for successful printing. Each participant will get a chance to practice with the software and print a small object to take home. Sample models will be provided, but participants may also bring in an STL file of a small (~3cm3) object to try out.
Completion of this class will grant authorization for using the 3D printers at MakeICT.
Time: May 24 06:30 PM - 08:30 PM
Register: http://makeict.wildapricot.org/event-5270381
3D Printing Basics
Time: May 28 02:00 PM - 04:00 PM
Register: http://makeict.wildapricot.org/event-5270383
Ages: 12 and up
Metal Lathe Basics
Time: May 20 11:00 AM - 12:30 PM
Host: Rustin Atkeisson
Register: http://makeict.wildapricot.org/event-5271409
Price: MakeICT Members - $19.00
Price: Non-Members - $24.00
Ages: 16 and up
Metal Lathe Basics will cover the basic parts of the metal lathe while also going thru the proper use and operation of the Craftsman and Logan metal lathes.
The end project will include basic operations such as facing and parting as well as knurling and adding internal threading.
Safety glasses are required.
Manual Milling Basics
Time: May 20 01:00 PM - 03:30 PM
Register: http://makeict.wildapricot.org/event-5271410
Price: MakeICT Members - $24.00
Price: Non-Members - $29.00
Ages: 16 and up
Manual Mill Basics will cover the basic parts of a manual mill while also going thru proper use and operation of the EMCO manual mill.
The end project will include basic operations such as facing, squaring, drilling, and counter boring.
Metalshop Safety must be completed before signing up for this class.
Metalshop Safety Class
Time: May 10 07:00 PM - 08:30 PM
Register: http://makeict.wildapricot.org/event-5271412
Price: MakeICT Members - $0.00
Ages: 16 and up
The Metalshop Safety Class will cover basic safety for working in both the Hot room and Cold room for the Metalshop at MakeICT, as well as some basic expectations. The following tools will be covered :
Pipe bender
Tubing roller
Metal shear
Large and small sheet metal brakes
Drill press
Hand grinders
Horizontal band saw
Vertical band saw
Chop Saw
Other equipment not listed may require further authorization. This class is required before taking most other metalworking classes or workshops.
Safety glasses are available but we recommend bringing your own if you can.
Time: May 23 06:30 PM - 08:00 PM
Register: http://makeict.wildapricot.org/event-5271413
Ages: 16 and up
Pipe bender
Tubing roller
Metal shear
Drill press
Hand grinders
Horizontal band saw
Vertical band saw
Chop Saw
ShopBot CNC Using Easel
Time: May 21 04:00 PM - 07:00 PM
Host: Doug Wilson
Register: http://makeict.wildapricot.org/event-5272459
Price: MakeICT Members - $25.00
Price: Non-Members - $30.00
Ages: 16 and up
Required Authorizations: Woodshop
This class is for those interested in using the CNC ShopBot in the woodshop. During the class, students will design a wooden ring on Easel.com and carve out said ring on the ShopBot. Carving on the ShopBot is quick and accurate, so each person will have the chance to operate the ShopBot themselves and take home a small token of their hard work.
Vinyl Cutting Basics
Time: May 21 02:00 PM - 04:00 PM
Register: http://makeict.wildapricot.org/event-5277483
Ages: 12 and up
Learn the basics of vinyl cutting and how to use the vinyl cutter at MakeICT! We'll cover how vinyl cutters work, how to convert vector files for cutting, and how to prepare and apply vinyl decals. Each participant will practice with the software and cut at least one single color vinyl graphic to take home. Vinyl and example files will be provided, but participants may also bring in a vector graphic of their own (subject to review) to try out.
Advanced Laser: Using The Rotary Axis
Time: May 26 06:30 PM - 08:30 PM
Register: http://makeict.wildapricot.org/event-5277484
Ages: 16 and up
Required Authorizations: LaserCutter
Learn to use the rotary attachment for the Laser Cutter to engrave things that are (at least roughly) cylindrical! We'll cover how to connect and set up the rotary axis and how to generate files. Each participant will get to engrave a glass or other object and take it home. Cylindrical objects will be provided, but participants may also bring their own (laser safe) objects to try out as well.
Arduino Basics
Time: May 27 02:00 PM - 05:00 PM
Register: http://makeict.wildapricot.org/event-5277485
Price: MakeICT Members - $30.00
Price: Non-Members - $35.00
Ages: 12 and up
Learn the basics of the Arduino platform! We'll go over the various hardware you can use, how to build basic circuits with an Arduino, and how to write the code to make it all work.
We have plenty of laptop computers to use. If you'd rather learn on your own, please download the Arduino IDE software from the following URL:
https://www.arduino.cc/en/main/software
All necessary hardware will be provided for use during the class.
Woodshop Authorization
Time: May 12 06:00 PM - 09:00 PM
Host: Jesse Schlenker
Register: http://makeict.wildapricot.org/event-5278054
Learn the basics to safely operate the major woodshop tools in this safety class including understanding the limitations of each tool, the forces created when using the tool and how to maintain safe control for improved performance. Tools covered: SawStop table saw, drill press, band saw, router table, jointer, planer, miter saw, oscillating spindle and belt / disk sanders and scroll saw. Expect at least two hours of walkthrough with our tools and equipment, followed by an OPTIONAL hour of hands on practice with the tools aimed at those who have little or no practice with woodworking tools
Prerequisites: Please read the woodshop tool access policy and safety requirements on the wiki page prior to coming to class. Safety Personal Protective Equipment (PPE): • Mandatory: Closed-toed shoes, eye protection, short sleeves • Advisable: Hearing protection
Upon completion of the safety demonstration you can use this woodshop equipment for your projects whenever you work at MakeICT as a member!
Amateur (Ham) Radio: An Introduction of the What, Why, and How (1 of 4)
Time: May 08 06:00 PM - 09:00 PM
Host: Randy Reynard
Register: http://makeict.wildapricot.org/event-5207849
Technician Class License Course. The class will be taught by FCC licensed amateur radio operators. The lead instructor is a registered ARRL License Instructor and an accredited Volunteer Examiner (VE) with the Laurel VEC. All the instructors are members of the Wichita Amateur Radio Club.
This class will introduce participants to what amateur radio is and how to become a licensed amateur radio operator. The role of making as it applies to ham radio will also be explored. The class will be very interactive to help ensure that participants leave with the information they need to pursue this fascinating and educational hobby. We will also discuss how a class to help prepare for taking the licensing exam can help with passing and knowing more about what you will do once licensed.
We will discuss plans for an amateur radio station at MakeICT in the Electronics and Rapid Prototyping Lab and will tour the Lab to explain how it will be integrated.
This series of four classes (three weekday evenings and one Saturday) will cover the material on the entry level (Technician) amateur (ham) radio examination. Students will purchase a textbook that the classes follow. The textbook is “Ham Radio School Technician License Course 2022-2026” and it includes online resources that support the text and classes. Students will purchase the book from Amazon. At the end of the Saturday Class, a no-cost test session will be offered.
The class schedule is:
Monday 5/8 6-9 PM (we’ll be asking people to arrive by 5:30 to get signed in and sign the waiver, if necessary)
Tuesday 5/9 6-9 PM (We’ll have some time at the end of this class for the MakeICT members who are present helping “host” the class to show people around)
Thursday 5/11 6-9 PM
Saturday 5/13 9-12 AM with testing starting at 1 PM
