Event Updates for December 2022
Metalshop Safety Class
Time: Dec 10 12:00 PM - 01:00 PM
Host: Rustin Atkeisson
Register: http://makeict.wildapricot.org/event-5067006
Price: MakeICT Members - $0.00
Price: Non-Members - $20.00
Ages: 16 and up
The Metalshop Safety Class will cover basic safety for working in both the Hot room and Cold room for the Metalshop at MakeICT, as well as some basic expectations. The following tools will be covered :
Pipe bender
Tubing roller
Metal shear
Large and small sheet metal brakes
Drill press
Hand grinders
Horizontal band saw
Vertical band saw
Chop Saw
Other equipment not listed may require further authorization. This class is required before taking most other metalworking classes or workshops.
Safety glasses are available but we recommend bringing your own if you can.
Time: Dec 13 06:00 PM - 07:00 PM
Register: http://makeict.wildapricot.org/event-5067007
Ages: 16 and up
Pipe bender
Tubing roller
Metal shear
Drill press
Hand grinders
Horizontal band saw
Vertical band saw
Chop Saw
Manual Milling Basics
Time: Dec 11 12:00 PM - 02:30 PM
Register: http://makeict.wildapricot.org/event-5067008
Price: MakeICT Members - $24.00
Price: Non-Members - $29.00
Ages: 16 and up
Manual Mill Basics will cover the basic parts of a manual mill while also going thru proper use and operation of the EMCO manual mill.
The end project will include basic operations such as facing, squaring, drilling, and counter boring.
Safety glasses are required.
Metalshop Safety must be completed before signing up for this class.
Metal Lathe Basics
Time: Dec 11 10:00 AM - 11:30 AM
Register: http://makeict.wildapricot.org/event-5067009
Price: MakeICT Members - $19.00
Price: Non-Members - $24.00
Ages: 16 and up
Metal Lathe Basics will cover the basic parts of the metal lathe while also going thru the proper use and operation of the Craftsman and Logan metal lathes.
The end project will include basic operations such as facing and parting as well as knurling and adding internal threading.
Powder Coating Basics
Time: Dec 13 08:00 PM - 10:00 PM
Register: http://makeict.wildapricot.org/event-5067010
Ages: 16 and up
Annual (2022) Christmas Ornament from Turned Wood
Time: Dec 17 01:00 PM - 03:00 PM
Host: John Nicholas
Register: http://makeict.wildapricot.org/event-5069288
Price: MakeICT Members - $10.00
Price: Non-Members - $15.00
Ages: 10 to 110
In 2021, this Introductory Class turned a hanging snowman Christmas Ornament. Sign up to turn a different Ornament, for 2022, for your home. We will cover safety, tool use and you get a nice Christmas Treat
Kid Friendly: Under 16 must be accompanied by Responsible Adult
Time: Dec 20 06:00 PM - 08:00 PM
Host: John Nicholas
Register: http://makeict.wildapricot.org/event-5069296
Ages: 10 to 110
Game Boy Macro
Time: Dec 17 12:30 PM - 02:30 PM
Host: Ben Rogers
Register: http://makeict.wildapricot.org/event-5073465
A Gameboy Macro is a modified Nintendo DS console that has had it’s top screen removed and a resistor inserted so that it still boots through the system checks without a top screen. The Gameboy macro is intended to play Gameboy advance games using original Nintendo hardware emulation.
The class will cover working with very small screws, taking out screens, shell modification and a tiny bit of soldering of a resistor and a speaker wire.
Every participant will leave with a working gameboy macro (that needs a bit of cosmetic touch up from removing the top screen). If anything breaks during reassembly I will have spare parts to ensure everyone completes the project.
All ages are welcome, but minors must have parents in the room.
Ugly Christmas Sweater Print Jam
Time: Dec 14 07:00 PM - 08:30 PM
Host: Doug Wilson
Register: http://makeict.wildapricot.org/event-5073582
Price: Non-Members - $5.00
Ages: 8 to 101
Bring a T-shirt to have an ugly Christmas sweater printed! Cotton or Cotton/Poly blend (Dark Color to complement the design.)
Set-up will start 30 minutes BEFORE the event for those curious to see tips on prepping a multi-color print.
All ages welcome, but the print may be too large for small children's t-shirts.
It’s always interesting to see your work, Doug. Will you be posting a picture of the print prior to the event?
Time: Dec 15 03:30 PM - 05:30 PM
Host: John Nicholas
Register: http://makeict.wildapricot.org/event-5069293
Ages: 10 to 110
Intro to MIG Welding
Time: Dec 29 06:00 PM - 08:00 PM
Host: John Miranda
Register: http://makeict.wildapricot.org/event-5064970
Price: Non-Members - $25.00
Ages: 16 and up
This class will teach you the basics for Metal Inert Welding (MIG) and set up on the Miller 211 welder. We will cover use of the Hot Area and welding safety. Once you complete this class you will be authorized to use the MIG welders in the metal shop. Long sleeves are recommended. If you have your own welding helmet and gloves you welcome to bring them.
Time: Dec 21 06:00 PM - 08:00 PM
Host: Doug Wilson
Register: http://makeict.wildapricot.org/event-5083857
Ages: 8 to 100
Woodshop Authorization
Time: Dec 28 06:00 PM - 08:00 PM
Host: Aaron Rivers
Register: http://makeict.wildapricot.org/event-5084235
Learn the basics to safely operate the major woodshop tools in this safety class including understanding the limitations of each tool, the forces created when using the tool and how to maintain safe control for improved performance. Tools covered: SawStop table saw, drill press, band saw, router table, jointer, planer, miter saw, oscillating spindle and belt / disk sanders and scroll saw. Expect at least two hours of walkthrough with our tools and equipment, followed by an OPTIONAL hour of hands on practice with the tools aimed at those who have little or no practice with woodworking tools
Prerequisites: Please read the woodshop tool access policy and safety requirements on the wiki page prior to coming to class. Safety Personal Protective Equipment (PPE): • Mandatory: Closed-toed shoes, eye protection, short sleeves • Advisable: Hearing protection
Upon completion of the safety demonstration you can use this woodshop equipment for your projects whenever you work at MakeICT as a member!
Laser Engraving: Rotary Edition
Time: Dec 21 07:00 PM - 09:00 PM
Host: Christian Kindel
Register: http://makeict.wildapricot.org/event-5084289
Ages: 16 and up
Required Authorizations: LaserCutter
Learn to use the rotary attachment for the Laser Cutter to engrave cylindrical things! We'll cover how to connect and set up the rotary axis and how to generate files. Each participant will get to engrave a glass or other object and take it home. Cylindrical objects will be provided, but participants may also bring their own (laser safe) objects to try out as well.
Laser Cutting Basics
Time: Dec 23 07:00 PM - 09:00 PM
Register: http://makeict.wildapricot.org/event-5084290
This class will teach participants how to use the 80 watt CO2 laser cutters at MakeICT. We will be using the LightBurn software to create and cut a simple project.
Participants will learn the capabilities of the laser cutter, machine and material safety, and operation of the machine in Cartesian (flat) mode. All participants will complete a small project to practice running the machine.
Please bring a USB flash drive if you have one. Completion of this class grants the necessary authorization to use the laser cutter.
Time: Dec 23 05:30 PM - 07:30 PM
Host: Aaron Rivers
Register: http://makeict.wildapricot.org/event-5084233
Time: Dec 28 04:00 PM - 06:00 PM
Host: John Nicholas
Register: http://makeict.wildapricot.org/event-5069303
Ages: 10 to 110
