Starting: 2019 Mar 30 - 3:00 pm
Ending: 2019 Mar 30 - 5:00 pm
Instructor: Josh Robinson
Register: http://makeict.wildapricot.org/event-3322298
Price: $10.00 for MakeICT Members and $15.00 for Non-Members.
Ages: 14 and up
