Starting: 2019 Feb 23 - 6:00 pm
Ending: 2019 Feb 23 - 8:00 pm
Instructor: Josh Robinson
Register: http://makeict.wildapricot.org/event-3255757
Price: $10.00 for MakeICT Members and $15.00 for Non-Members.
Ages: 14 and up
Each participant will powder coat and cure a metal part that they will be able to take home with them.
