Starting: 2018 Oct 18 - 6:00 pm
Ending: 2018 Oct 18 - 8:00 pm
Instructor: Jerry Carpenter
Register: http://makeict.wildapricot.org/event-3090677
Price: $15.00 for MakeICT Members and $20.00 for Non-Members.
Required Authorizations: Woodshop
The object of this workshop is to build a small pine wooden step stool, kids size, to use to get a drink or to stand on to brush teeth. The steps are listed below. Painting/Staining would be done off site. This is an entry level workshop that will demonstrate use of several tools in the woodshop. A follow on workshop will be hosted in the future to make a rustic step stool.
- Cut a 2 x 8 x 8 ft to 16.00 long slabs.
- Use the thickness planner to cut down to 1.375 thick.
- Use the drill press to drill 4 holes on a compound angle. Fixture provided by me.
- Use the miter saw to cut 2 x 2 x 8 ft into 20.00 long legs.
- Use the lathe to round over both ends of 2 x 2.
- Use drill motor with tenon cutter to cut 1.00 round tenon on both ends of 2 x 2. Provided by me.
- Use miter saw to cut compound angle on center of 2 x 2.
- Sand and glue up stool. Glue requires 24 hours to set before moving.
MakeICT member Jerry Carpenter is our workshop host who is a woodworker extraordinaire specializing in hand made rustic items. He is also a member of the Sunflower Woodworker Guild.
