An indexing/dividing head?
yes, sitting by the granite flat surface.
Thanks Rustin…next time you rn the lathe authorisation I’ll twist your arm to show me how to use correctly
What are you trying to do with it? You can index it in 1 degree increments. Works like a vernier scale. Unless the one at the space is different, it should use 5C collets. Most don’t have a square base so you’ll have to indicate it in, depending on what you are using it for.
Looking at cutting brass gears
Depending on the tooth count you may have to approximate some teeth. A dividing head or at least a rotary table may be better choices. If 360 can be evenly divided by the number of teeth, the spin indexer can work
