Cut Polyester Felt on Laser?
Hi! It looks like the internet feels okay about cutting polyester on a CO2 laser, but I wanted to ask here before doing it. The full project will engrave on 1/16" plywood and cut through the plywood and felt. Any concerns or precautions I should take?
Your power required to cut through the wood may give you melted edges on the polyester rather than a clean cut plus the smoke rising from the wood will darken you polyester around the cut edges. Probably better to cut them separately and then bond them for a cleaner appearance.
