Attempted to load filament on the Creality CR-10. It appears something is obstructing filament from going thru the filament run out sensor.
I know we had a member who tried to run a job set up for PLA while ABS was in the printer. He said he cleared it, but I suspect he did not. I’d guess it will have to get to ABS temps before you’ll be able to clear it.
If it’s failing to go through the run-out sensor I doubt it has anything to do with running with the wrong settings. That part doesn’t get hot.
