Heads up,
The CNC plasma cutter is temporarily out of commission.
There is a short somewhere in the magnetic read switch for the torch height control. Jimmy is looking into the issue and thinks it shouldn’t take much effort to fix.
Heads up,
How goes the CNC plasma repair? Just checking before I make a trip in later this week
The cnc plasma is still down.
We traced the issue down to that magnetic sensor.
It sounds like Jimmy will look at it tomorrow and hopefully the fix will be pretty simple.
I’ll let you know if Jimmy gets it fixed tomorrow.
Just wondering on the status of the plasma CNC.
It should be working fine now. The sensor on the probe is loose and needs a better way to fix in place. However, it was working just fine Thursday night.
Thank you.
