Cut or rip
50” x 50" squares sheet
46” x 46" squares sheet
48” x 48” blanket
(2) 3” x 41” strips
Press all layers to make flat add starch as needed to make stiff.
Lay out the first layer of 50” x 50" squares sheet spray with quilt basting spray.
Roll up the 48” x 48” blanket and place 1" from edge of sheet on top. Unroll and smooth flat. Spray with quilt basting spray.
Roll up the 46" x 46" sheet place 1" from edge of blanket on top. Unroll and smooth flat.
Draw a line every 5 inches across the width of the panel parallel to each other .
Check hold of spray basting and add pins if needed.
Stitch through all layers at drawn lines. I used 5mm stitch length.
Square up and trim to 42” square.
Sleeve: Double fold in 1/2" on the 3" and stitch. I used 3.5mm stitch length.
Serge the edges of the panel serging in the sleeves perpendicular to the quilting lines.
Fold under 1/4" on the raw edge of the sleeves and top stitch. There should be 1/2" between the edge of the sleeves and the edge of the curtain. I used a 3.5mm stitch length.
Bind edge with 1" twill tape. Will need to find binding foot.
